NOS mini wiring, which ECM wire for TPS signal?
Which TPS wire do you guys use for the NOS mini?
Pin 8 on the Blue ECM which is 5 Volt Reference TPS Pin "A"
or
Pin 24 on the Red ECM which is TPS Sensor Signal Pin "C"
When in programming mode on the NOS mini, if I use Pin 8 on the Blue ECM, it only displays 5.0 when setting up the TPS setting in step #9 of the instructions. You hold the pedal to the ground and it just stays at 5.0.
After programming mode has ended, the NOS mini displays "1 2"
When in programming mode on the NOS mini, if I use Pin 24 on the Red ECM, it displays 0.7, and then when I hit the pedal to the floor it shows 3.6v
After programming mode has ended, the NOS mini displays "r 2".
CH2 isn't even hooked up to anything.
I am using the CH 1 blue wire out of the NOS mini for my solenoids, and I'm using the white/blue wire which is Trigger input CH 1 for the TPS signal, which I've tried connecting to both Pin 8 on Blue ECM and also on Pin 24 on Red ECM.
Why am I not getting 4.5 shown on the NOS mini when setting up the TPS an why am I not seeing "r r" once program mode is completed?
I'd rather avoid running another wire across the bay to hook directly into the blue wire on the TPS.
Do I have a bad NOS mini? I bought it used from a member on here.
I have TPAS mode set to 02 btw, so on the nos mini it shows 8.02 when programming it.
or
I'm fighting mini probs of my own right now also but different. As far as voltage goes though your pin 24 if rising with pedal is what I'd be using. My personal car I only get 3.5 or 3.6 volts from and will only display 95% tps in hptuners. If the car was working fine at that voltage before it will still be fine now. The mini automatically sets what voltage to kick on by the step 9 process, don't quote me but I think it's 90% of the highest displayed value. That can also be manually changed.
The stage 2 is always displayed 2 on ours also and we have nothing hooked to it. Ours though if you set the window switch to anything other than zero it displays 1 at full throttle and doesn't do anything. Set window to zero and it sprays as soon as you go full throttle. They had us send the little display back saying that was the prob. Got it back from them all original settings were still display and had the same results. We are getting ready to try a different controller all together.
When you say you set the window to anything other than zero, you mean if you set it for say 3000 rpms activation it displays "1 2" on the NOS mini screen?
I'm thinking i need a new cable or I need to adjust it so that it says 4.5 at WOT just so that it is correct.
Tightened the cable and got 4.6v.
TB wasn't even opening up to 90.
If you do the TSC relocation mode to behind the ECM, may want to check to see if you didn't pickup some slack in the cable when moving it around like I did.
Now to log this and see if timing is getting pulled.
Mine is 4150 throttle body with some home made cable and stuff. Reading your second post I was getting ready to post about the slack adjuster but it appears you found it. Make sure you do the tps relearn again and I always set the tps activation lower. In my track logs no matter how hard I think I press the pedal I always lift a little on launch. As I said mine reads 95% in hptuners at full throttle and I've went as low as 84% on launch. Need to slide seat up I guess
