78mm truck plate on LS6 intake?
Old 07-27-2017, 12:20 AM
TxFireman1972's Avatar
Default 78mm truck plate on LS6 intake?
Is anyone running the Nitrous Outlet 78mm truck plate on a LS6 intake? I have a Fox mustang with a LS1 that has a LS6 intake/TB.
I came across a deal on a Nitrous Outlet 78mm kit. Only thing I can tell for sure on the plate is that it has the fittings on the side instead of facing rearward like the F-Body kit does. So I'm wondering if anyone is using this plate on a LS1/LS6 intake?
Old 07-28-2017, 03:45 PM
Nitro Dave's Nitrous Outlet's Avatar
You could use a 78MM Truck plate on a LS6 Intake manifold no problem. You will need a 3an 90* swivel on the nitrous side to keep the soft line hose really close and tight to the plate. This should allow you to have clearance from the the throttle cable on the nitrous side. The Fuel side will clear no problems. You just could not use the F-Body specific hardlines for that system which is part number 00-10122-78-hl. You will have to use the soft line hoses to connect from the solenoid outlet to the plate fitting. Since you are using a LS6 manifold you will want to use 00-54021 solenoid brackets to mount them in a clean nice area. If there is anything else you need feel free to let us know and we will be glad to help you out and get you taken care of. Currently we are having our Nitrous Outlet Summer sale going on which is 10% off N.O. products only. Feel free to give us a call directly if you have any questions 254-848-4300 that is our sales number.
Quick Reply: 78mm truck plate on LS6 intake?
