Spark Plug Recommendations H/C/I 75 Shot
I have searched and havent had any luck! Car currently has a cam, ls6 intake, and heads on it. Car dynod at 425Hp without spray. Compression 11:1. I was spraying before my head and cam install and went with Br7ef plugs gapped at .35. I want to spray a maximum of 75hp shot on top of this setup. Should I keep the plugs or swap them out to something new? Also, is the gap sufficient?
Thank you ls1techers!
