Best for NO PREP stinger 3 vs fogger
New setup,just bought a holley dominator efi setup,looking to buy a stinger 3 plate 2 dry stages,or a fogger with 2 dry stages,which is best for no prep stuff ?I like the plate cause its a lot cleaner less stuff going everywhere and even distribution with this type of plate.
Not sure which would be better for you. But I will say compare jet change time from a fogger to the plate. I went with a plate because of the jets but I'm also on a wet kit so yours wouldn't be as bad. I've seen nothing but good results from the stinger 3 so it shouldn't be a prob. Some people on the bullet spraying a lot of nitrous through it without distribution problems.
I dont see why you couldn't get it done with the plate. If you are familiar with reading spark plugs, you can use the ICF&ICT function in the Holley to correct any cylinder to cylinder variations that you see. Of course, the direct port is always the best way to go, but there's a pretty sizable price difference.
