Window switch rpms
Old 02-19-2018, 08:04 AM
Sladester2's Avatar
Default Window switch rpms
What rpms do you guys recommend to set a window switch at? Im shifting at 6500 and have a 4k stall. Dont really wanna spray right off the bat. Car can brake stall to around 3000
Old 02-19-2018, 07:50 PM
ragtopz28's Avatar
I'm set at 3,000 but, I want mine to hit as soon as converter flashes. I also spray through the shifts to 6800. If you don't have a progressive then I guess just play with the rpm above the flash to come in when you want.
Old 02-20-2018, 10:17 AM
Sladester2's Avatar
Thats what i was thinking, maybe 3800-6200 but then it almost seems like a waste. Don't wanna spray during the shift tho
Old 02-20-2018, 10:25 AM
ragtopz28's Avatar
Are you concerned about your rear/trans? Do you have a particular goal?
Old 02-20-2018, 12:14 PM
Sladester2's Avatar
Trans mostly. I'm running 7.1-7.2 in the 1/8th cam only with a 1.5 60ft. I'm trying to hit 6s
Old 02-20-2018, 12:44 PM
ragtopz28's Avatar
What controller do you have? Will it progress? What size shot?
Old 02-20-2018, 05:14 PM
Sladester2's Avatar
No actual controller just a lnc for timing, window switch, wot.. Might end upugetting a progressive controller
Old 02-20-2018, 07:21 PM
ragtopz28's Avatar
I like the NOS mini...does all kinds of stuff
Old 02-20-2018, 07:58 PM
Sladester2's Avatar
If I don't get the gains I'm wanting, spraying from a bit after flash to a bit before i shift you better belive I'll get one lol. I don't plan on sprsying much of a shot right now though
Old 02-20-2018, 07:59 PM
Sladester2's Avatar
Do I even need a lnc eith a nos mini?
Old 02-20-2018, 08:16 PM
ragtopz28's Avatar
I don't have/need a timing puller. I do it in the tune (currently at 18.5*, every car wants something different) on a 150. The mini lets you bring it in in % or time or both in decimal seconds. I just bring it all in on the hit, through the shift, and out the door
Best on a 150 is 9.91 @ 135.2 1.34 60'
Going to a 175 and 200 pill this weekend
Old 02-20-2018, 08:23 PM
Sladester2's Avatar
Nice runs! Idk if I'm as brave as you I just want a couple more tenths lol
