Best Head Gasket for 350 shot....
Old 02-20-2018, 07:41 PM
CanadianEh!'s Avatar
Default Best Head Gasket for 350 shot....
Hi Guys. Going from my LS402 in a 3900 llb Car runnIng 9.60s at 142mph to new set-up looking for low 9s. I am going to a SHP LS Next Steel 434 c.i. with 4.155 inch bore, 4 inch stroke and 1/2 inch Head studs. Heads are Brodix 6 Bolt BP BR 3. Martin smallwood spec’d Cam: 246/262 at .629/.612 and 115+4. Lunati Pro Series I-Beam Rods and Custom Diamond Pistons. Compression 12:1. My question is about Head Gaskets. I had no problems with Head sealing on my LS402 on a 300 shot on a N.O. Plate. I’m going to a Direct Port and a 350-400 shot. I know I don’t have as much material between the Bores with the 4.155 Bore. I’ve been researching Titan ISC Head Gasket that uses a built in ring for each cylinder with a Copper Gasket but does not require o-ring machining. Also looking at Cometic MLX 6 Bolt Head Gasket. Appreciate any feedback from anyone spraying my intended 350-400 shot. Thanks!
Old 02-21-2018, 10:32 PM
blk00ss's Avatar
I was spraying 300 with a 4.155 bore and a regular 6 bolt cosmetic mls gasket. They looked perfect when I pulled it apart. I ordered the mlx gaskets but ended up with regular mls again. But I will be spraying 450 this time. And I’m not expecting any issues with the gaskets. Plenty of guys have sprayed way more than this on regular mls cometics.
Old 02-22-2018, 07:53 AM
Thanks for the input ...much appreciated!
Old 02-22-2018, 10:02 AM
Zmg00camaross's Avatar
Good tune up will be the best head gasket saver lol!
Old 02-23-2018, 08:26 AM
pantera_efi's Avatar
Default Perfect Combustion Energy Requirement
Hi Eh!, I believe your "gasket" tech is good.
I have used a different method, NOT at your bore size.
I have fit BFG Helical seals around the combustion chamber @ $65.00 each cylinder. (gas filled)
My concern is your combustion quality, your Ignition Energy Requirement.
I would fit my IGN-1A coil kit for your case.
I would fit the NASCAR Spark Plug of an Autolite 3922x Racing.
I would fit FireCore 250 SPW.
YOUR lever of power, 400 shot AND 12:1 C.R., will place a great demand for Ignition Energy.
KEEP you engine happy, NO Miss-Firing allowed.
Lance
Old 02-23-2018, 02:03 PM
"I MAID THEESE"
Mavn's Avatar
Lance
Autolight plugs? I wouldn't run those in my Lawn Mower
Old 02-23-2018, 09:34 PM
blk00ss's Avatar
Don’t question his genius.
