Nano Nitrous - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Nano Nitrous
Old 05-18-2018, 04:32 PM
Default Nano Nitrous
I have a little coffee set up on my car. Without a bottle heater. I am looking at the nano nitrous stuff. Anyone have experience with the nano Nitrous stuff? I am thinking about doing it instead of a bottle heater.
BlkOps is online now
Old 05-18-2018, 04:41 PM
HCI2000SS's Avatar
To be honest I'm not sure this Nano stuff is really necessary. At least with smaller shots. My bottle heater does a pretty good job at keeping pressure up until I get down to the last 2 to 3 lbs. And for the extra cost of this system I'm not so sure it's really worth it, when a good heater will be effective enough. This is just my experience and opinion
HCI2000SS is offline
Old 05-18-2018, 06:03 PM
Hmmmmmmmmmmm...
What kind of heater do you have?
I am only spraying 100. And I will be sticking with only 100 for a while.
Old 05-18-2018, 06:22 PM
AgFormula02's Avatar
Nano works. It helps keep pressure/flow constant through the pass. Important in the 1/8th, really important in the 1/4.
This is magnified as you move to a bigger shot.
I used the system until until we went turbo.
Even on the dyno we noticed it helped maintain the right a/f ratio through the whole pull. (Usually the longer you are on it, you tend to richen up as pressure drops.)
nothing aginat heaters. They get the initial pressure up. But with Nano you donít drop pressure as much.
the downside is you can show 1200 psi while having little to no nitrous in the bottle. You need to weight bottles always.
AgFormula02 is offline
Old 05-18-2018, 06:33 PM
HCI2000SS's Avatar
Originally Posted by BlkOps View Post
Hmmmmmmmmmmm...
I don't know the exact model number, but it's from NX and the heater automatically adjusts for optimum pressure. The Nano is cool and All, but in my opinion just not worth the extra expense with something like a 100 shot. In a 1/4 run I might drop a 100 psi which quickly goes back up. Hardly enough enough to change power and AFR. In fact, when we were tuning the car my tuner had no problem keeping the AFR stable through out the run
Old 05-18-2018, 09:39 PM
'68LT1camaro's Avatar
These bottle heaters are inexpensive and work great. I have three heaters from this company. Fantastic products and dirt cheap.
http://pronitrous.com/home/815-proni...-240w-12v.html
'68LT1camaro is offline
Old 05-19-2018, 12:16 AM
How much was your nano set up?
Old 06-12-2018, 08:01 PM
dreww's Avatar
I have the 3000psi nano setup. Ive used it on a 125 shot so far. Never used a heater so wont knock it. I chose nano cause I didn't want to wait for a bottle heater. I also didn't like feeling the power drop thru a pull as the bottle pressure dropped. 3000psi tank gets filled at local paintball park
dreww is offline
Old 06-13-2018, 11:48 PM
But in reality, that's not really a good argument. Most people won't blast down the street or track unless their engine and oil is warmed up. When you first start your car and that heating process is taking place, the warmers are also bringing the bottles up to temp. So you have to wait on your car to warm up regardless. Once your engine and oil is warmed up, your bottle pressure is there, so you're ready to go. If you run a big shot with a single bottle and you feel like it's taking too long to get your pressure back up, run two warmers on a single bottle. If you feel like your pressure drops off too much during the run, then run two bottles plumbed in parallel. Maybe I'm just old school but it seems silly to me to buy a nitrogen bottle when I could just buy another nitrous bottle (& warmer) to maintain pressure longer AND double my nitrous capacity or just buy another cheap bottle warmer to heat the bottle quicker if I'm on a budget.
Old 06-27-2018, 12:05 PM
Here's my experience. Back when I was shooting a 125 shot, I picked up half a second and 4 mph when I turned on the nano. That was leaving the current n20 jet in it and just putting a smaller fuel jet.
then I had issues with the regulator. It would always go to 1350 when I opened the nano. That's to high. Tom darnel was hella old and not much help. It's under new ownership tho.
I just run a 15lb bottle and a big *** arc full wrap bottle heater now.
but it does work and does what it's suppose to. Price has gone up tho. Use to be 400 for a kit back them.
SF 1HOTLS1 is offline
Old 06-27-2018, 12:07 PM
If your into roll racing the nano is a good idea. Cuz after 1 run on the highway pressure falls pretty good and your opponent is not going to wait 5 minutes for you to build up pressure again.
anddd if you spray at a lower pressure your not taking full advantage of your system and it's bad to run rich.
Old 07-11-2018, 04:46 AM
Nano is super convenient. Even more so for any nitrous use outside of drag racing at the strip.
I live near a circuit track which hosts street meet style events, where people cruise around the track at a slow pace and roll race on the straights, basically simulating a cruise down the highway or around town except completely legal.
I wouldn't even bother going without Nano. I can do back to back runs at optimum pressure and my AFR is always on point. Plus I can drain the entire bottle before seeing performance drop off.
veezee is offline
Old 08-08-2018, 10:00 PM
NANO works. Flat out. I’m surprised it’s not more commonly used. My car picked up 100 ft lbs of torque with the nano and like 30 hp. My 250 shot put out exactly the same pull after pull, pass after pass. I have the 4500 psi kit which I don’t think they sell anymore and now the bottle is expired so I can’t get it filled either. The down side is having to go to a paintball park to get it filled. I haven’t sprayed my car in a few yrs so I haven’t worried about it. It’s mostly a garage Queen or I drive it to work once in awhile.
ls2 bait is offline
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
