Wanting nitrous what size shot will it handle safely 383?
Here's my ? I have a 383 stroker I will list a build sheet with it. Long story short I bought the car with the motor already built and wanted to know which power adder (would like to go nitrous route) would be the best for it I will list all the info I have on the motor. Thanks in advance.
crank-4340. Rods-4340 H beam 6.125
Pistons- icon icon 962 Bearing- cleavite
dish-12cc. Oil pump-melling
Rings- hastings. Lifters-ls7
rockers-std Can gear-billet
crank gear- billet. Timing chain-rollmaster
bore-3.905 stroke-4.0
block-ls1 Decked-.003
heads-as cast? Milled-.002
c.c.-68. File fit top-.030
Second-.032 oil-.015+
headgasket- std Thickness-.051
pusrods- 7.375 valve intake-2.00
Valve exh. 1.550. Valve springs-pac 1206x
cam- Las 111 duration-248/254
lift-.625 .620
That's the info I have was wondering if I can add more power to it or is it just a good n/a motor any help will be appreciated.
lift-.625 .620
