Help!! Lean spike on the hit
Using a NX MAF kit on a ls1 pulling off the rail. On both 75 and 100 hp jets my WB picks up a momentary lean spike right after the nitrous hits .The spike lasts roughly .2 secs. What could be causing this?
is it normal?
How can this be tuned out?
is it normal?
It could be bottle pressure, fuel pressure, the length of the nitrous line, length of the fuel line..
nitrous typically flows faster/quicker than the fuel side. old school guys worked around this by changing the length of the lines from the solenoid to the jets/plate.
If you are running and aftermarket ECU, like Holley EFI there are some things you can do to help with it.
