Flashing a converter with a dry shot. - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Old 03-15-2019, 12:03 PM
Default Flashing a converter with a dry shot.
Okay guys just want to make sure my theory is sound before I blow up my car. I have a single nozzle dry kit that I want to use. I want to spray right out of the hole with a stock converter. It will be a progressive shot 175 with a 20% start point. Race gas plugs and a good tune will be used obviously. I'm also going to start at a 75 shot and work my way up. My question would about cylinder pressure with spraying that low. I should be good with the progressive shot correct? Oh by the way 99 TA A4 bolt on car 3.73 gear.
Thanks
Gotsboost is offline
Old 03-17-2019, 09:39 AM
I don't know about that my man.
First time spraying and you want to use a progressive dry system to start with?
dannyz is offline
Old 03-17-2019, 11:42 AM
not my first time man. I have had 7 different nitrous cars. This is my second ls1 based car with a dry kit. Really surprised nobody has done this.
Old 03-17-2019, 02:10 PM
Stock converter is a pretty low stall. What controller are you using? You could possibly wire both stages of the controller to the single kit. Example have stage 1 set at 20-25 percent start and end amount coming on at the hit. The have stage 2 on a delay for .3-.6 seconds until rpm's are up where you happy. Have the second stage start percentage the same as the first stage and ramp to 100 how ever fast you'd like.
tug686spd is offline
Old 03-18-2019, 07:49 AM
Just running the one kit. Using the new nitrous express EZ controller.
Old 03-18-2019, 09:25 AM
"I MAID THEESE"
Mavn's Avatar
How about you just buy a converter??? Lol
Mavn is offline
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
