How to hook a Fuel Pressure Gauge up to NXL?
Ok, I want to hook up my fuel pressure guage and my fuel pressure switch. Now I know I need two d6 manifold with one port on each to make each side equal on the rails. Where can I get these? Part number? I know I have seen a pic of someones set up on here.
Do a search on my username and you can find my pics. I monted the fuel pressure sender on the driver side NXL rail. You need a -6an adapter with 1/8"NPT on the side. I believe the Russel PN 670340 is the right one. I puut one on eash side. I have my FPSS on the passenger rail. Also I saw your track results. You should really put that car on a wideband dyno before running at the track. Otherwise you are ricking engine damage.
Good Luck
Good Luck
Fuel gauge is easy -- take the allen-headed pipe plug out of the adapter in the back of the rail (whichever rail is easier for you). Thread in your 1/8" NPT line there, and route it up to your gauge.
