LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Nitrous Oxide (https://ls1tech.com/forums/nitrous-oxide-10/)
-   -   Timing Tuner's Window Switch Function (https://ls1tech.com/forums/nitrous-oxide/212046-timing-tuners-window-switch-function.html)
TigerFan187 Sep 3, 2004 05:05 PM
I was reading the instructions for the Timing Tuner and am trying to figure out if it gives you the option to not spray through shifts. Is that what the Maximum RPM function is?
chevy42083 Sep 3, 2004 09:53 PM
Yep, you set the "window" to close just before the shift.
FYI, I've been asking around wether or not to spray through the shift and the general concensus is that it is faster, but harder on parts.
© 2026 MH Sub I, LLC dba Internet Brands
