finaly, 9's!!! went to NED yesterday. 1st pass with a 2 tenth delay went 10.1 2nd pass went with no delay, had a small fuel issue and the car bogged a tad went a 1.6 60' and 9.9 @ 137 some suspention tweeks and im off!!!! then take the car from 3540 lbs to 3,300 and a biger jet and low 9's i hope!!! :chug: |
OMG you ran a 9.9 with a 1.6 60" :jest: ya Id say deep 9's are in your future congrat's on getting the new setup :hail: :hail: :hail: :chug: arent you glad your not fighting the forced induction battle anymore??? |
thanks man. i'll tell you what, i love FI, and i think all my issues i found this year was all the same shit, and i bet i could have gone as fast with my old setup had i spent all the hours fixing shit. i sold it all do to the fact it didnt run right, thinking N2O would be so much better, then it all hit me. im very happy with my new setup, East side did a great job on the motor, and i helped out and did a ton of work myself, so between myself and them, we built a nast set up with lots left! cant wait!! |
Kick ass man...glad to see things going good! |
thanks |
Congrats!!! How much did you end up throwing at it nitrous wise? |
the big 9.9 :hail: :hail: :hail: :hail: :hail: |
this was done with a 200 shot, but lower bottle psi she was a little lean, so im working on a little fuel system stuff, and add some more timing and bottle pres for the next time Thanks Vinny, to bad you had to run. hit me up on my cell, i have 4-5 bottles need toping off befor next weekend |
Congrats Bro, Could You just go into a little quick detail about Your Nitrous setup? Thanks. :cool: |
Congrats, looks like 9.7's would be very easy for you. |
Noyzee.....congrats man, glad to see your single digit midget! Ditto on pics or at least a little description please. Get that suspension sorted out and you will be easy in the 9.5 range or better, damn. Now all you have to deal with is filling bottles.....and you already 4-5! Good luck Charlie |
Great job! Love to hear more about your setup, engine, n2o, etc... |
Congrats !! |
Congrats on the 9 second slip. |
No problem on the setup. it is an East Side Performance 347 that i helped put together, i worked very close with ESP on pulling the motor assembling it, putting it back in ect ect. its a stock block, stock nitrated crank fixed up by Wheel to Wheel, lunati rods (i polished them myself for oil reasons) rod bolts, stock mains, custon dimond pistions coated bigger ring ect, ESP custom grind cam (kind of top secret info lol, but not as big as most think) ESP ls6 heads dual springs, valve job by SK machine here in mass,stock ls6 intake, stock pp t-body, stock water pump power steering, no short belt thing, Kooks 1 7/8" headers, stock maf, stock computer with ESP tuning, fuel fuel system, 42* inj. N2O set up is running off my existing fuel system, but the pump isnt keeping up, so this weekend i will be doing a seperate cell for the nitros. but the kit is a custom kit put together by ESP and myself, it is based on a NOSzle kit but with big noids, custome brackets bla bla bla. this setup has alot more in it, and these runs have been done on a 200 shot. im planning on 60' ing the car to try to get in the 1.4's, and in that case i should see a 9.7 out of the car, then this winter, up the shot, remove some weight, and get the car cert to run fast and go at her next season |
You ever get the car dynoed on that 200 shot? What kind of TQ converter are you using? |
yes, the car makes about 650 with mild tuning. she was a little lean tho, now with the new fuel setup i should be able to bring the bottle pressure up and add a little timming i think around 675-700 depending how well it goes. tq is impresive tho. na the car mad 465!!!!!!!! on the spray the dyno gets all f-ed up spins tires and the tq blows right away, ive gotten 200 rwtq all the way to 800 rwtq, so it is off every time. it is a Huges vert |
Congratulations... 9 second club is pretty exclusive. NOGO really does good work tuning these beasts :hail: |
| All times are GMT -5. The time now is 12:07 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
