Nitro Dave's Halo Video Hey, I just thought I'd share this video I made of a test fire of the Halo kit I got from Nitro Dave's VIDEO The video was shot with my 200 Jet, a 78. Running the 50 jet, the kit is great for you guys with traction issues, very soft hit on my ST3500. Ryan K |
That is the COOLEST thing I have ever seen. |
I have the kit being controlled by my Dynojet Wideband Commander. Its a pretty sweet setup, the WBC has a built in relay controller. The controller is user configurable to be RPM, TPS, and AFR activated. Since I have a loose converter, I don't need a window switch, So I have it set to come on if the TPS is >90%, and the AFR is <13.5:1. It also turns the relay off before the rpms hit the limiter at 6150 rpm. Talk about safety. The WBC is a great add on to ANY nitrous system. Ryan K. |
Ryan, Thats cool.Im gladd you like it. Dave |
yep, it works :) |
looks like a kid on chrismas day with a new toy. |
I have a video of it being sprayed into the motor while on the dyno. I will try and dig it up and post it ;) |
Originally Posted by Ryan K I have the kit being controlled by my Dynojet Wideband Commander. Its a pretty sweet setup, the WBC has a built in relay controller. The controller is used configurable to be RPM, TPS, and AFR activated. Since I have a loose converter, I don't need a window switch, So I have it set to come on if the TPS is >90%, and the AFR is <13.5:1. It also turns the relay off before the rpms hit the limiter at 6150 rpm. Talk about safety. The WBC is a great add on to ANY nitrous system. Ryan K. Exactly how I have mine setup with the WBC. I like it. Although the N2O has been on the car for 2 months now and I still haven't been able to spray it at the track yet. Was getting ready to spray it last weekend but the posi decided to blow up at the starting line instead.... :( Looks nice. I like how stealthy the halo setup is. I was going to get that but decided to build my own spray bar instead. |
How much for just the halo? I have a friend that might like something like this. |
Yeah, Id say it works :cheers: |
Sweet.. |
ok....how much and where can i get that!! |
absolutely. how much???? |
Great Video! Thanks! I had never seen the Halo setup! It looks really nice Dave! Is the halo setup only made for the LS1/Lid? |
Right now it is But I can custom make what ever you need. Ryan ,Thanks for the link. Dave |
can you make something simular but for a wet kit? Or is the MAF kit the best option? |
Dave-Will the whole kit need to be purchased,or can the halo components be purchased seperately to add to a existing dry set up? |
i think i saw that be4 in wal mart in the vigi. section hehehe j/k |
Originally Posted by DEEZ98Z can you make something simular but for a wet kit? Or is the MAF kit the best option? Ryan |
| All times are GMT -5. The time now is 05:07 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
