differen't oil for nitrous? i'm curently running mobil 1 synthetic 10w30 in my car with 40 thousand miles. i just put in my nx shark nozzle kit. I will be running a 100 shot maybe 150 in the future. should i be ok with my oil or should i go with 10w40? all info is appricated. |
I drain my oil out before I go to the track |
You will be fine. The nitrous may cause higher temps in the engine but not ver a long enough time to justify a higher weight oil. I also change mine more often. Every other track visit if I am spraying but it probably isnt needed that much. |
Originally Posted by Narcoleptic SS I drain my oil out before I go to the track |
draining the oil saves weight!! nice weightreduction right off the nose. lol moblie one is great oil, as long as you keep it clean, what your doing is fine. |
what do u guys mean by draining out your oil? |
less oil = less friction = better times :eek2: |
Its a joke |
its not real, i wouldnt try it. lol the moble 1 is fine. |
Yeah,when I really need to go fast I remove : the motor oil, the antifreeze, the transmission oil (a good 10 lbs right there), one headlight, the rearend fluid, and take off my left shoe:jest: Thats my trick anyway. |
Originally Posted by 860 Performance Yeah,when I really need to go fast I remove : the motor oil, the antifreeze, the transmission oil (a good 10 lbs right there), one headlight, the rearend fluid, and take off my left shoe:jest: Thats my trick anyway. i have big shoes too, that should work great, :D |
you go lightweight!! |
i just barf out my window in secon gear. that usually cuts a full second off my et. |
I wear nothing but slippers and a leopord skin g-string. :jest: |
i hang my ass out the widow and fart, thats like after burners! :fart: :lol: |
This thread took an awfull turn somewhere... :jest: :jest: When I race Noyzee, I'm going to be wearing nothing but a SFI fire jacket and helmet! Thats some weight savings, plus I'm filling the interior of the car up with helium, no need for that heavy atmosheric air in my ride! |
When you race Noyzee, yor going to loose because my g-string will be way smaller. lol |
| All times are GMT -5. The time now is 09:19 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
