LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Nitrous Oxide (https://ls1tech.com/forums/nitrous-oxide-10/)
-   -   cutting back the ground strap on tr6's. (https://ls1tech.com/forums/nitrous-oxide/274952-cutting-back-ground-strap-tr6s.html)
one92rs Feb 11, 2005 11:26 PM
has anyone tried cutting back the ground strap on a set of tr6 plugs to see if they work any better. was just wondering.
CAT3 Feb 12, 2005 01:35 AM
Nope, never wanted to as I have always had excellent results with the TR-6's. Interesting option though.
one92rs Feb 12, 2005 07:23 AM
i have seen it in big shot apps. was just wondering. i think i might try it just to see.
deezel Feb 12, 2005 08:01 AM
Can you explain why you would want to do this?
I thought the reasons for using colder plugs were: 1) colder temp reduces chances of detonation; and 2) smaller gap reduces chances of spark blowing out due to higher cylinder pressure. If you cut the groud strap, it seems like that would make the gap larger, negating the effect of #2 above.
AgentOrange Feb 12, 2005 04:23 PM
its a age-old trick and you still gap it. It's just now the spark is more exposed to the CC and you get a better flame front.
http://performanceunlimited.com/docu...degapping.html
one92rs Feb 12, 2005 08:27 PM
man im gald you explained that for me. im not sure if it will work but i am going to try it out.
CAT3 Feb 12, 2005 10:28 PM
Guess its like indexing plugs = FPITA! Post up your results if you decide to try it, which in theory should give some positive results.
Charlie
Beast96Z Feb 12, 2005 10:39 PM
Looks like it makes since......
taner Feb 13, 2005 09:42 PM
why not run the correct plug???? :confused: call me crazy, lmao!!!
white2001s10 Feb 14, 2005 01:03 AM
excuse the note in the pic, but try some of these Autolite 472 plugs.
They already have shorter grounds and are perfect plugs for the bottle.
http://infernious.net/filedepot/mike/plugs1.jpg
MUSTANGEATER Feb 14, 2005 01:30 AM
LMAO BO,
I used Autolites on my car with the bottle.
© 2026 MH Sub I, LLC dba Internet Brands
