Spraying tnt 100 should I move up to 150? Hey guys, Ive been spraying a tnt 100 shot for a while and have LOVED the performance. Car is nasty on the spray. I got awesome results with the 100 shot (125rwhp). Car made 494rwhp and 565rwtq with just a intake and a catback. I have headers going in soon and will retune so I am wondering if I should just step up to the 150 shot. Am I getting greedy? Should I just stay with the 100shot. Let me know your input. -Zee |
I would spray the 150 and wouldnt look back |
I don't think a 150 shot is greedy at all. Just make sure you can fuel it and then go have fun. :) |
Be careful using the TNT 150 shot, remember they underrate. Just tune it and run it as safe as you can. Your car will be a monster with the headers/150shot/and a tune. |
Go for it, just make sure your fuel system can handle it. |
Uhh hell yeah. Then a 200 will be just around the corner. Then....... |
Originally Posted by Turo Go for it, just make sure your fuel system can handle it. Fuel system is stock on my zo6. Ill put it on the dyno and see how it runs. Use if a bigger fuel jet if needed and go from their. Should I take out any timing? Thanks for all the info guys. :) |
i would at least get an in-tank pump for a tnt 150. as far as timing, i pull about 2 degrees out just to be safe, but theres a few people running stock timing with no problems. |
Originally Posted by Turo i would at least get an in-tank pump for a tnt 150. as far as timing, i pull about 2 degrees out just to be safe, but theres a few people running stock timing with no problems. SDB |
Go for it. Stock fuel pump will support your needs on Z06. Plenty of guys are running this HP with stock pump. Don't qoute me but I believe stock fuel system can support the 150hp shot. Do a search on corvette forum in n20 section to be sure. |
i would go for it a lot of the guys at my local track are running 150 shot on stock fuel system and tune |
Ok, so thats what Im going to do. 150shot and retune. Hopefully I wont run lean! What kind of #'s do you think Ill make. I made 494rwhp 565rwtq on the 100 shot. Thats 125rwhp increase! Does the TNT 150 shot hit just as hard? Im thinking 175rwhp increase?? |
It'll hit alot harder. It feels good. It's hard to say if you'll make 175 at the wheels. You can be sure you won't make any less than 150 though. :nod: |
Be sure to check your sparkplugs ( pull at least one and inspect) after spraying 150. |
I`m running 150 with H/C. I had fuel issues. Added a intank fuel pump and bigger injects. Car in sig! Made over 600rwhp on stock bottom with the spray and love it! |
150!!!! |
Originally Posted by b18c1hybrid Uhh hell yeah. Then a 200 will be just around the corner. Then....... -somebody |
Still running the ZO6 clutch? |
People from smithtown dont go fast anyway |
Originally Posted by gollum Be sure to check your sparkplugs ( pull at least one and inspect) after spraying 150. |
© 2024 MH Sub I, LLC dba Internet Brands
