Small N2O bottels Where can i get like 2lbs bottle??? Scott |
Check out NitroDaves and Dynotune they are both sposors of this board and sell small bottles.:chug: |
Yes we sell 2 lb bottles. |
2lb bottle are usually motorcycle bottles and will need to be mounted with the valve down wherever you are hiding them... |
still cant see why someone would HIDE nitrous |
Originally Posted by dame still cant see why someone would HIDE nitrous I'ts this little thing called Streetracing. Hidden nitrous is one of the oldest hussles ever. |
Originally Posted by Aries :eek2: I'ts this little thing called Streetracing. Hidden nitrous is one of the oldest hussles ever. Scott |
Originally Posted by Aries 2lb bottle are usually motorcycle bottles and will need to be mounted with the valve down wherever you are hiding them... |
I just depends on weather or not there is a pick-up tube in the bottle, no tube = upside down |
hey man i noticed when i took my AIR pump off ( you know , in the front bottom driverside fenderwell) it looked like a 5 lb bottle would fit nicely if you made some brackets and it even has a little access door |
© 2024 MH Sub I, LLC dba Internet Brands
