LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Nitrous Oxide (https://ls1tech.com/forums/nitrous-oxide-10/)
-   -   what's a good a/f to be at when spraying? (https://ls1tech.com/forums/nitrous-oxide/335875-whats-good-f-when-spraying.html)
oufan2929 Jun 13, 2005 12:52 AM
I've heard anywhere from 12.0-14.0, just depending you you're talking to. What's a good, safe a/f? thanks--andy
DONAIMIAN Jun 13, 2005 02:23 AM
14.0 :eek2: thats to damn lean even for a N/A motor. Right now im at 13.0 and sometimes run into minor octane related problems.
GM Muscle Jun 13, 2005 06:34 AM
I always run 11.0-11.5 to be relativly safe. I don't think I would ever set the car up to run past 12.0 on the bottle.
koolrayz Jun 13, 2005 07:23 AM
I also shoot for a flat 11.0 It also depends on how much your spraying IMHO
if your only blowing a 100 shot then you would be OK with a 12.0 I would definately stay at or below 12.0
Nitro Dave's Nitrous Outlet Jun 13, 2005 08:58 AM
We tune most of our Nitrous cars around 11.8 to 12.1.In some casses we will go as high as 12.5.Depending on the customer.
Dave
01Blackerado Jun 13, 2005 09:27 AM
So whats the real danger in the higher AF numbers besides obviously leaning out!!?? Is it more for insurance if the pump or injector or something fuel related fails!!??
Robert56 Jun 13, 2005 08:41 PM
The leaner a/f's will pound your motor into a paper weight. I set mine up currently at 11.5/11.8 depending on rpm and torque.
cyipher Jun 13, 2005 11:21 PM
I run 11-11.5
© 2026 MH Sub I, LLC dba Internet Brands
