What should air fuel ratios be when spraying. I have a 99 C5 air filter and exhaust and was wondering what my afr's should be when spraying a 100 or 150 shot on a wet kit. |
It varies; it's really up to you. The richer you are (up to a point) the safer you are, but the richer you go the less power you'll make. I would not go much leaner then 12.2 ish and not much richer then high 10s on that size shot. Matt |
I like to run mine on the safe side. 11.0 to 11.5. :) |
Anything under 12.0 should be safe. I would rather leave a few ponies on the table then lay the $$$ on it! |
Same here, makes good power and still on the safe side.
Originally Posted by GM Muscle I like to run mine on the safe side. 11.0 to 11.5. :) |
Cool thanks for the help. |
11.5 to 11.7 depending on where at in my curve. Robert |
© 2024 MH Sub I, LLC dba Internet Brands
