why use a stand alone fuel??
Old 09-21-2005, 10:44 PM
phoenix's Avatar
Default why use a stand alone fuel??
why would you want to use this for your nitrous set up?
what are some pros and cons on this set up?
Old 09-21-2005, 11:12 PM
chpmnsws6's Avatar
pros- run better fuel for the nitrous, less stress on the main fuel system, more controlled unit, can be a low or high PSI
cons- price, more stuff in the car
Old 09-21-2005, 11:24 PM
Elite_Hot_Rod's Avatar
Because FUEL is dedicated to the Nitrous system alone, running lean on nitrous is one of the worst things you can do to a motor, things have a tendency to get really hot. A dedicated fuel system also allows the stock fuel system to provide engine fuel only thus hopefully decreasing any chances of low fuel pressure.
Old 09-21-2005, 11:25 PM
gator's 99TA's Avatar
c16 costs 10 dollars a gallon. putting it in the fuel tank sucks.
best of both worlds with a stand alone.
Old 09-22-2005, 10:50 AM
Closed ex-Sponsor Account
NXRICKY's Avatar
Hell it looks cool with the right one.. And o yea all the things everyone else said.
Ricky
Old 09-22-2005, 04:12 PM
phoenix's Avatar
another ? if i were to do this sence i can control pressure couldnt i just turn up or down the fuel pressure instead of changing jets? is there a level sensor? how would u know if ur low on fuel and run out
Old 09-22-2005, 04:48 PM
NXRICKY's Avatar
Sure turning the pressure up or down is alot finer adjustment then swapping jets.. Do not know if the tanks come with sensor from the pics I have seen I would say no, there is not one..
Ricky
Old 09-22-2005, 04:53 PM
NitrousDirect's Avatar
Let's you run a higher octane mixing in with your nitrous
Old 09-22-2005, 04:54 PM
You have to open the fuel cell and check the fuel level manually.
