can my stock car take a 125 shot?
i think you would be fine with that shot i sprayed open 5177 solenoids which is about 140 to the rear wheels on my stock motor it ws a dry shot. just watch your timing and airfuel if possible pull about 4-5 degrees of timing just to be safe.
Your stock bottom end can. But when/if you put the cam in and do a tune I'd look at pulling some timing if you add any and take a look at your fuel system. It wouldn't hurt to upgrade it at that point.
Matt
Matt
Originally Posted by Lennyd
can my stock 00 camaro z28 handle a 125 wet shot?
Yes you'll be fine. But there are always general things that are good to do as precautions like pull 1.5-3 degrees per 50 HP, a set of colder plugs, and if you want to run 150 or more HP then upgrade the fuel pump, might want to consider a fuel pressure safety switch also
