need a quick answer on blowdown tube
It would look best if you just put a -8AN 90* swivel hose end on the bottle. And then just get some cheap -8 braided line. It doesn't have to hold pressure, braided vacuume hose will work.
Just to give you an idea.
Use -8 all the way to the bulkhead fitting. I have dual 15# bottles with plumbed intoa -8 Y connection to a single line going to the bulkhead. Its on a C5 but it shouldn'y be much different. My.02
Originally Posted by gr8one99SS
what size fitting do i need to run a braided blowdown line on a N.O.S. bottle. I want to mount the bottle between the back seats.
FIRMLY attached.
Hawk
Originally Posted by 227Hawk
Rules just say vented to exterior. You can use any hose w/ any attachment that will pass tech. Example= silcone hose w/hose covers, as long as it is
FIRMLY attached.
Hawk
FIRMLY attached.
Hawk
Originally Posted by slowpoke96z28
aren't most burst discs set at about 3,000psi? i'd want to use line that was rated for high pressure so it vents outside the car and not just bust those hose.
robert
Don't use rubber hose and a hose clamp. Definetly use AN lines (should be teflon AN lines).
And most importantly, make sure you use a bulkead fitting where it exits the car. Don't just push the hose out through a hole. Because the tube will whip around like a firehose on nitrous, its super violent.
Vinny
Vinny
