whats the biggest i can juice my 02 Z28. wet or dry whats the biggest i can juice my 02 Z28.wet or dry The only thing i have done is the lid. didnt wanna pussy around with little mods, but i do wanna get some safe h/p. i wil be getting headers soon also. my car also had the 3.23 axle option, so i think it will be pretty quick for a stocker n02 car. |
well first off "little" mods are what get you the optimal results. to me why spray a stock car and run like what 12.50s? when you could have a complete bolton car running high 11s low 12s(look in my sig). I wouldnt consider that pussying around. Doesnt make much sense to me to spray and run 12.50s when you can have a bolton car run just as fast if not faster. just my opinion |
Easy 100/150 wet or dry. a nice 100 shot will normaly knock a sec off your ET. If I can help let me know. :drive: Robert |
150 wet all day. The most power, with the least hastle. Just change your plugs and your set. |
thanks. im gona go ahead and get headers n a tune because my 4l60e feels a little sloppy to me i wanna get those shifts thightened up before i put anything through them. robert56 i looked through the website. very nice i will contact you when i am ready to start buying shit |
Originally Posted by FloridaZ 150 wet all day. The most power, with the least hastle. Just change your plugs and your set. |
Originally Posted by 2001z I hate to beat a dead horse but a 150 shot wet you might want to upgrade that pump. |
Originally Posted by 2001z I hate to beat a dead horse but a 150 shot wet you might want to upgrade that pump. Yo udon't think he'd need an upgraded fuel pump if he went with a 150 shot wet or dry? |
Many people have run without one. Myself included. Sure it would probably be a good precaution. 150 is definatly the max without one. I trust my FPSS. |
150 is max,but to be safe i would change fuel pumps,jmo |
Originally Posted by 1badA3Z 150 is max,but to be safe i would change fuel pumps,jmo I ask cause I am going to get a 150hp dry shot soon and I heard a while back that I needed to upgrade my fuel pump. I figured if that was the case (since it would be such a pain in the ass) that I'd just put smaller jets in till I could afford to do the pump upgrade. But if I can get away with the 150hp shot.........balls to the wall baby. :devil: |
ha ha i hear ya,goodluck with it just keep a check on ur plugs and supporting equipment,thats the life of the kit and ur motor |
Originally Posted by 00Vette I ask cause I am going to get a 150hp dry shot soon and I heard a while back that I needed to upgrade my fuel pump. I figured if that was the case (since it would be such a pain in the ass) that I'd just put smaller jets in till I could afford to do the pump upgrade. But if I can get away with the 150hp shot.........balls to the wall baby. :devil: |
Robert???
Originally Posted by camaroextra im pretty set on getting a wet system. from what i have researched 150 is a lot for a dry shot with a stock system. and the dammage that running lean is often severe. in my humble opinion a wet shot is worth the money I hope Robert chimes in! I was talking to him about this exact same subject a few months back because I have been wanting a 150hp system for a while. Originally I wanted a wet system. He said that dry is better. He is the guru and can speak educatingly about this subject, and I can't so I'm not going to try! Robert? Can you chime in here? |
Don't get me wrong camaroextra, I'm sure they both have there ups and downs and I'm not trying to sway you from the wet system. I just want Robert to explain why the dry system is better! I forgot. :bomb: |
Originally Posted by 00Vette Don't get me wrong camaroextra, I'm sure they both have there ups and downs and I'm not trying to sway you from the wet system. I just want Robert to explain why the dry system is better! I forgot. :bomb: |
Im spraying 150 wet all day every day too and i have yet to see a problem...i tried the 100 just wasnt enough...and now the 150 isnt so im gonna go 200...good luck camaroextra |
i used a wet 200 motor rated (143 rwhp) on my 00 formula with only a SLP airlid. went 11.97 @ 117 with a 11.99 next pass. auto 3.23 gears. all stock fuel system as well. |
Originally Posted by camaroextra the fuel pump right? where does a wet kit tap into the fuel line? http://www.stealthram.com/familypics...2osideshot.jpg |
Originally Posted by FloridaZ 150 wet all day. The most power, with the least hastle. Just change your plugs and your set. :drive: |
© 2024 MH Sub I, LLC dba Internet Brands
