Timing Tuner with FJO?
I would assume that the Timing Tuner and the FJO controller can be used together. Can someone give me an idea of how these would be wired together?
Are you referring tothe FJO mini progressive controller or the Maximizer II (also an FJO built controller)? Either way we can get you a wiring diagram to connect the two.
I'm referring to the FJO 2-Stage Mini Progressive controller. I'm thinking about buying one but I already have the Timing Tuner and want to make sure I can get them to work together without a degree in electrical engineering.
Help
Originally Posted by silverZ98
im intrested in this too
Thanks and Merry CHRISTmas!!!
This is a very simple wiring setup, BUT REMEMBER you have to use a wot switch instead of the tps of the FJO unit.
If any of you have any questions just pm myself or Ricky. Just as a side note, Ricky noticed a way of wiring the two together while still allowing you to use the TPS for activation, BUT you lose the progressive control which kind of defeats the purpose of a progressive controller. We can get a wiring diagram for this setup if anyone wants it, just let us know.
