can you run a half wet/ half dry shot.
1 Post
can you run a 75 dry shot before the maf, and maybe a 75 wet shot after. withouth needing to get new injectors or a new fuel pump
the purpose of this would be to split the fuel responsability between the injectors and the fuel pump.
eh eh anyone?
eh eh anyone?
how you arrive at the power you make does not matter for the fuel pump. It is simply the total amount of power that you make that determines fuel pump requirements.
That being said you certainly would not need bigger injectors if you choose a two stage dry/wet setup, just the fuel pump.
Plus you would prob spend as much $$ in the extra noids, lines, nozzle and etc to hook up the wet side you'd almost have paid for bigger injectors to spray the whole 150 dry.
I agree you'll need a pump for 150 hp or more regardless of wet or dry.
1 Post
Originally Posted by 1badA3Z
get a pump just to be on the safe side
