Well decided to go to.....
dual nozzles for my new LT1. Before i had the TB plate and i dont want to blow up my new engine cause of the n20 not getting to the 1 and 2 piston.
So i will be buying 2 nozzles for the n20 side and the fuel side and will be placing prob right at the (curve) of the rubber intake elbow. Will be placing on both sides.
Is this doable?
or do i have to run 2 lines into 1 nozzle and run other 2 lines into the other nozzle, which will be 4 lines total. Thing is i only have 2.
Please let me know.
Thanks
Randy
Is this doable?
Please let me know.
Thanks
Randy
Both fuel and N2O have to go into the nozzle for it to work right.
If you increase the fuel through your injectors when on the bottle, and jet down the fuel side of your nozzles you reduce the distribution error significantly. It's just another option.
Originally Posted by Cobra Commander
That's crAzy!!!
j/k yeah you need two per nozzle
you and ur "thats crAzy" statement on LS2...hahahha
well w/e..
so just go ahead and put in on one side, instead of both?
and just need to purchase 1 nozzle huh?
hold on. Im a bit confused. Does the nozzle come with 2 jets that fit inside the nozzle. Example of the Y shaped nozzle. In which one jet goes on one side of the Y and the other goes on the other side of the Y, then combining the mixture of n20 and fuel. (both comming out and mixing together at the same time)
hopefully this makes since!
lol
Randy
Originally Posted by white2001s10
Yes, I think you've just invented the fogger nozzle.
lol thanks!
I have that kind of thinking powers, which tends to payoff sometimes!
