Fuel questions
Old 03-19-2006, 05:20 PM
bodydropped's Avatar
Default Fuel questions
What can I spary on a stock fuel pump without a tune on a 98 z28 m-6?
It's a nos plate kit.wet.
Old 03-19-2006, 05:33 PM
Matt@HSW's Avatar
Depends on what size shot and what your other mods are.
Matt
Old 03-20-2006, 12:05 AM
Jet hot lts,3.73's,ram clutch,slp lid.Motor wise it's stock.I want to spray 150.
Old 03-20-2006, 07:44 AM
Matt@HSW's Avatar
You should fine. If you want to play it extra safe you could upgrade the fuel pump. Down the road if you do a cam/heads I'd suggest a pump at that point.
Matt
Old 03-20-2006, 08:37 AM
Big Geek's Avatar
Or mix in some high octane to raise you octane rating and slow your burn rate until you decide to replace your pump. Hope this helps.
Jim C.
Old 03-20-2006, 09:13 AM
TN94Z's Avatar
150 should be okay on the stock fuel system.
Old 03-20-2006, 09:59 PM
I got 15 gallons of MOTORSPORT 109
Produces more power than any other unleaded fuel. Recommended for higher boost applications with CRs up to 11:1 or naturally aspirated engines up to 13:1.
• Color: Clear
• Motor Octane: 101
• R+M/2: 105
• Research Octane: 109
• Oxygenated: Yes
• Specific Gravity: .722 at 60° F
All of that was straight from VP's web site.Is that ok to mix in while spraying?
Old 03-20-2006, 10:10 PM
227Hawk's Avatar
It's a 1998 , i'm thinking the fuel pump could use some T.L.C. ( You got a 8 yr. old pump - pump cost is cheaper then motor.
My.02
Hawk
