Gonna spray it with the new DP kit this weekend.
I finally found the time to get my new NX direct port kit on. I plan on spraying 175 through it this weekend at the track. I am trying to get this thing in the 10s before the tranny lets go. I currently have 20 (N2O) and 12 (Fuel) jets in it. I do not have anything smaller than the 12 fuel jets right now. Do any of you think this is too much fuel per nitrous for this? I can step up to either a 24 or 26 nitrous jet. I think those would put me at the 200 hp range. Thanks for any help.
I'm guessing he's running high pressure from the fuel tank. There's no mention of a
standalone. Yes you can regulate the high pressure after the fuel rails.This will help lean the fuel shot. But that tuning needs to be done under controlled parameters.
(Dyno and wideband) then followed by careful track tuning.This is a great way to fine tune. But not something you want to do blindly or without the proper ground work.
Hawk
Hawk
I am running the stock fuel pressure. I do have a 255lph intank pump and a fuel accumulator to help with the initial hit. I do not have access to a dyno and wideband over here. I will have to read the spark plugs to see how rich it is.
