LT1 dry
LT1 dry
Alright, so the LT1 maf dosen't add fuel. I know I have to run the rubber tube from the zex box to the fuel pressure regulator. My question is can I spray before the MAF? I have a grantelli MAF, so it dosen't have a screen. So I guess I am wondering if it affects the MAF or not, can I install the nossle into my K&N intake or should I install it in the elbow after the MAF?
the lt1 maf does provide fuel...have it running on my lt1.
with your Zex kit the nitrous is sprayed AFTER the MAF or you will run very very rich.
If the MAF on the LT1 does supply fuel, why did the ZEX kit go the route of using the rubber hose? Can I spray before the MAF and not use the hose??
when running a dry kit (MAF) you can't adjust the fuel mixture unless you do pcm tune.
if you have the zex just run it the way it came.
