Purge quit working?
Purge quit working?
So the purge decided to crap out on me. I took the noid off and tested it but it wont do anything. Does this happen a lot with the NX stuff?
Problem is I bought it used, is it still under warranty though? And where do I send it?
And Dave I hven't forgotten about you, I will get those pics for you asap!
Originally Posted by BTLFEDSS
Noid might of shorted these things happen some times,better than being stuck open
BTLFEDSS
BTLFEDSS
~on mine, if you hold the button down for longer then a few good seconds, the fuse blows...or something like that! did you hold the button down for a long time???
no I just pressed it to make sure everything worked.. I had to fix the ground wire on the fuel/nos solenoids and when I went back to do it again it didn't work. Then I ran wires directly to it and its just dead.
