Where can I get O2 sensors for use with leaded fuel?
Old 07-17-2006, 09:30 AM
Tony Shepherd's Avatar
Default Where can I get O2 sensors for use with leaded fuel?
I searched and did not find a good answer. I know it has been asked before. I need an O2 that will hold up with leaded race fuel.
Thanks
Tony
Old 07-17-2006, 01:01 PM
Restricted User
CAT3's Avatar
Denso makes a set that holds up pretty good from what I have read, but I havent used them myself. I have had good luck with stock O2's, either mixing or straight, as long as I've run it all out at the track. I'll see if I can find the PN.
Old 07-17-2006, 01:07 PM
Restricted User
CAT3's Avatar
https://ls1tech.com/forums/showthrea...nso+O2+sensors
Here you go.
Old 07-17-2006, 01:55 PM
Thanks man!
Any other options? Anyone?
Old 07-17-2006, 06:52 PM
n2ocamaro's Avatar
I have about 600 miles on the Densos. They hold up really well.
Old 07-17-2006, 09:39 PM
Navy David SS's Avatar
Tony this is where I bought my Denso's. Ran them for 2 years on 114 Sonco Blue. Still ran perfect the day I switch to a different set-up.
http://www.densoproducts.com/results...ctCategoryID=2
Good luck on your car.
David
Old 07-18-2006, 07:34 AM
Thanks for the info!!!
Just ordered what I needed.
From the site:
"Constructed with Denso's exclusive aluminum oxide trap, this extra layer helps to protect from silicone and lead poisoning which causes premature sensor failure."
