LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Nitrous Oxide (https://ls1tech.com/forums/nitrous-oxide-10/)
-   -   11's in the GTO (https://ls1tech.com/forums/nitrous-oxide/586381-11s-gto.html)
rosm187 Oct 3, 2006 07:53 PM
11's in the GTO
ran an 11.98 this past saturday at bradenton.....
rundown goes like this
r/t .442
60' 1.904
330' 5.14
1/8 7.792@92.74
1000' 10.074
1/4 11.98@118.17
so i have dropped a little over 2 tenths, in just practice, and the weather might have helped me a little......
i hope to get an 11.7 before putting a stall in the car.
what do you all think?
am i keeping up with an f-body.....even slightly?
Robert56 Oct 3, 2006 08:50 PM
Great run, get the 60'er down a bit and you'll be even quicker. Add your time to the GTO n2o list in the stickies, good for 3rd place at this time. :)
Robert
BuBbABFP Oct 4, 2006 05:48 PM
great pass! my buddy went 11.6 at 120 1.8 60, he has catted Xpipe, Magnaflow weld ins, and a cold fusion 150 shot.
05gto60 Oct 4, 2006 07:11 PM
hopefully me and my gto will be in the 11s with you too. im running a TNT 150 shot with jba shorties and catless mids, volant intake, fuddle 3200 stall converter, and shift kit. It put down 443 with some WS problems and a rich A/F ratio (bottle pressure was a little low). the thing that sucks is that by the time i got to the track, i didnt have much nitrous left :bang:
GasTiresandOil Oct 4, 2006 08:42 PM
Congrats and welcome
rosm187 Oct 5, 2006 05:05 PM
thanks guys, and 05gto60, with it all set up right, you should run low 11's
i hope to get an 11.4 with a verter
05gto60 Oct 5, 2006 05:22 PM
i gotta work on my 60fts first. with DRs i only got a 2.0 whereas i had a 1.9 on street tires before. i think the track wasnt preped good though
juicedls1 Oct 5, 2006 05:27 PM
Good luck on the verter my car ran the fastest it has ever ran with the stock stall on a 150 nos kit 1.52 60ft 4.65 330ft 7.17 1/8th 9.42@107 1000ft after the verter it only ran 1.65 60ft 7.78 330ft 7.34 1.8th 9.62@106 1000ft weather and track cond. was the same it just felt like the verter (fuddle 3600 2.2str) slipped to much but this was on a 99 vert camaro.
rosm187 Oct 5, 2006 07:16 PM
well if you look at my sixty you can tell im now spraying out of the hole......
which i plan to do so with the converter, and if i can drop 2-2.5 tenths in my sixty, that should give me .4-.5 seconds, along with winter i hope to reach my stated goal.
i dont think spraying below 2800 would be too good on the stock stall...JMO
keep practicing, you should be able to get a low1.7 with that verter, if you do it conservatively.....
02NHRAtransAm Oct 5, 2006 08:04 PM
congrats :) nice times :judge:
© 2026 MH Sub I, LLC dba Internet Brands
