LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Nitrous Oxide (https://ls1tech.com/forums/nitrous-oxide-10/)
-   -   Won't activate @ WOT (https://ls1tech.com/forums/nitrous-oxide/624385-wont-activate-wot.html)
Ditmeion Dec 14, 2006 06:17 PM
System is a TNT F1 with a MSD window switch on a M6 98 TA.
Works fine when I arm system before going WOT...but while going WOT (within window switch RPM) and then I hit the switch in my dash to arm it nothing happens, if I blip the throttle (turn TB switch off then on) it kicks in.
So, does anyone know a way to get it to activate, when I have it floored and then hit the arming switch?
TIA
NHRATA01 Dec 14, 2006 06:37 PM
How come you want to arm it after its hit the activation point though? Thats kind of a strange way to use it.
I'm betting its something to do with the window switch needing to see voltage or the tach signal in a disengaged state first before it will activate, probably a built-in fail-safe of some type.
Ditmeion Dec 14, 2006 07:05 PM
I was wanting to see how well it would hold up spraying in 1st, so I just wanted to start spraying at higher RPMs and work down...easier than changing the pills after each run. I originally noticed my problem when I was racing in 4th and wanted a little "kick"...did same thing till I blipped throttle.
Todd157k Dec 14, 2006 08:26 PM
Sounds like your wot switch is on NC not NO... or did I miss something?
black98ws6ta Dec 14, 2006 09:44 PM
If you dont want it to spray till the upper rpms then dont floor it till its time.
© 2026 MH Sub I, LLC dba Internet Brands
