a few noob questions
Old Jan 25, 2007 | 01:16 AM
GoFast908Z's Avatar
Default a few noob questions
Ok, i searched a bit but didnt' find it. so here goes.
If i got 2 bottles, can they be run together, so that when one runs out the other takes over?
2nd question, what size bottle will fit btwn the rear speaker in the sail panel and a Stealth subw. box? 5lb? 2(1/2?) lb?
Old Jan 25, 2007 | 09:54 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
This can be done very easy.....you run a short line off each bottle to a Y or T fitting.
http://www.nitrousoutlet.com/catalog...product_id=347
Not sure on this one....how much room do you have behind the sub box?
Old Jan 25, 2007 | 10:03 AM
GoFast908Z's Avatar
there is no room behind the box. But there is in front of it. Think of how people put big bottle wher the spare tire would go, it would have to be at an angle like that, but much smaller. I'll snap a picture of the space available.
Old Jan 25, 2007 | 10:06 AM
brad8266's Avatar
just y them together and they will drain equally.
Old Jan 25, 2007 | 11:16 AM
GoFast908Z's Avatar
here is the space available:
It does go down to the bottom, but there is only a few inches of room at that angle:
here is the other side:
I may take the rear seats and seatbelts out too, will that help?
Old Jan 26, 2007 | 09:44 AM
GoFast908Z's Avatar
.....anyone?
Old Jan 26, 2007 | 10:22 AM
Chris@NitroDaves
Guest
Posts: n/a
Here are some bottle measurements so you can see which one might fit. Some of these will not fit but I put them in for measurement purposes.
10 0Z MINI-BOTTLE (W/MOTORCYCLE VALVE) (2" DIA. X 15.09" TALL)
1.4LB BOTTLE (W/ MOTORCYCLE VALVE) (3.2" DIA. X 11.38" TALL)
2.5LB BOTTLE (W/ MOTORCYCLE VALVE) (4.38" DIA. X 12.37" TALL)
5 LB BOTTLE (STANDARD PF VALVE) (5.25" DIA. X 17.64" TALL)
10 LB BOTTLE (STANDARD PF VALVE) (6.89" DIA. X 20.19" TALL)
12 LB COMPOSITE BOTTLE (PURE-FLO 100+ VALVE) (6.79" DIA. X 23.25" TALL)
15 LB BOTTLE (STANDARD PF VALVE) (6.89" DIA. X 26.69" TALL)
-Chris
Old Jan 26, 2007 | 12:50 PM
GoFast908Z's Avatar
the smaller bottles, can they be fitted with a standard fitting instead of the motorcycle one?
Old Jan 26, 2007 | 02:27 PM
Chris@NitroDaves
Guest
Posts: n/a
The motorcycle valve is a little smaller that the standard 45* Vavle. It will still flow 400hp and it has the standard -4 hook up for the mainfeed line.
-Chris
Old Jan 26, 2007 | 03:40 PM
GoFast908Z's Avatar
flow 400hp? meaning up to 400 out of the car or a 400 shot?
Old Jan 26, 2007 | 03:42 PM
SPLATT's Avatar
he means 400HP of N20
Old Jan 26, 2007 | 03:47 PM
GoFast908Z's Avatar
ok, so would i have to get any special fittings or anything for them?
Old Jan 26, 2007 | 04:11 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
no they do not require any special fittings....the handle is different not the fittings
Old Jan 28, 2007 | 12:12 AM
GoFast908Z's Avatar
what size bottle would fit (with bracket) under these:
http://www.speedspecialty.com/store/...duct=rrseatcvr
Old Jan 28, 2007 | 09:09 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Copied from the link you provided...
Not only do they look great and save weight, you can hide an amplifier under them (approx. 14"x14" of room, optional cooling ports available) or modify them to hold speakers.
from that information these should work
Old Jan 28, 2007 | 12:16 PM
GoFast908Z's Avatar
on your site i dont' see the 1.4 lb bottle, but i do see a 1 lb bottle.
*edit* nevermind, i found it
