Dual Stage 2 MSD WS's 2 Activations Switches All Done! 1 Attachment(s) All done but not working right. :eyes: i have everything set up exactly like the diagram but for some reason my relay is rapidly pulsing when it send power to the solenoid. if i bypass the FPSS or the WS, the relay will open correctly and provide 12+ volts to my solenoids.... but when both FPSS and WS are used inline to provide a ground to the relay, the relay will only send 5-6 volts to my solenoids. solenoid seems to spray fine with the 5-6 volts but i'm concerned about the relay making the rapid pulsing noise and wear on the solenoid. what do you think? |
Try by passing the FPSS with a jump wire. here's the one I used on my dual stage, maybe some insight. i didn'y really go over your diagram, but sounds off hand like FPSS, or maybe WS? http://www.geocities.com/whitetransa...ousdiagram.JPG Robert |
just hearing MSD window switches and pulsing reminds me of the exact same thing that my MSD digital switch did. my dyno graph looked like a lie detector test :lol: |
i got the relay to work right as far as relay staying completely open now. i haven't tested the setup yet because i'm out out of nawz. hehe. got a 100 lbs coming tomorrow :) . Dan from Dynotune suspected that it was the FPSS and was right so far because i got the relay to send out 14 volts to the solenoid and the relay stays open. i had to back off on the FPSS 1/4 turn. i hope that's not a sign that my fuel pressure is low. :eyes: i'm using the FPSS from my 5177 kit and from the reading on here, it's set to 35 psi as default. i don't have a FP gauge. anyone want to give me 2 cents? |
Originally Posted by 02NBMWS6 just hearing MSD window switches and pulsing reminds me of the exact same thing that my MSD digital switch did. my dyno graph looked like a lie detector test :lol: |
| All times are GMT -5. The time now is 07:07 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
