MSD Timing Twister
How does this work exactly? I understand that it is wired into the PCM at the crank and cam pickups. Is it mounted on the dash? How do you actually switch modes? I am guessing that you need to push a button for n/a driving (advanced timing) and then push a different button for using nitrous (retarded timing). Is that correct? THANKS
Its very simple and works great. Well worth the investment.
john
does it have a built in window switch like the timing tuner or do I have to buy one with it
