LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Nitrous Oxide (https://ls1tech.com/forums/nitrous-oxide-10/)
-   -   150 wet with Racetronix FP and SVO's (https://ls1tech.com/forums/nitrous-oxide/795252-150-wet-racetronix-fp-svos.html)
JEB99TA Oct 8, 2007 07:03 AM
Will a 150 wet hit max out my fuel pump and injectors? I have the Racetronix electric pump and 30# SVO's that are supposed to be flow rated at 36#'s. What are your thoughts? :confused:
GregWS6&z28 Oct 8, 2007 03:28 PM
i dont think you should. you would be close.
Breaking Stuff Oct 8, 2007 04:59 PM
You should be fine on the fuel pump. Injectors only need to be upgraded on dry hits.
ls2 bait Oct 8, 2007 05:20 PM
mine did just fine. pressure dropped to about 55 psi but provided more than enough fuel to give a 10:1 a/f.
OffspringZ28 Oct 8, 2007 07:00 PM
youll be fine. do it on a dyno first tho
mrr23 Oct 8, 2007 07:17 PM
wet kit has zero affect on the injectors. i ran a 150 shot on stock pump for almost two years. you are fine.
© 2026 MH Sub I, LLC dba Internet Brands
