LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Nitrous Oxide (https://ls1tech.com/forums/nitrous-oxide-10/)
-   -   help me plz to run 10's (https://ls1tech.com/forums/nitrous-oxide/829360-help-me-plz-run-10s.html)
eminem1833 Dec 12, 2007 11:02 PM
i have an A4 98 camaro thats run 11.88@119
241 stock heads,TR224-563-112 ,full boltons, stock TC
(LT headers, xpipe, dual dynomax muffler, 78 fast intake,
80 BBK TB, NGK TR55 spark plug, K&N CAI, 255 walbro fuel
pump, ASP crank Pulley , 160hypertek thermostat,
BMR K-member, QA1 Stocker Star R-Series Shocks
(adjustable), QA1 Generation F Series Springs (275 lbs),
342 gears, some weight removal)
How much nitrous is it going to take for me to see
a 10.XX pass?
i wanna spray it much it can get (120-150-..... safty with
my little mods)
thanx aloot
eminem1833 Dec 13, 2007 01:07 AM
plz i wanna some info today plz
what kind of plug or timming, .... etc??
waitting ur reply
thnx
Mike@HSW Dec 13, 2007 05:54 AM
a 150 shot should get you into the tens, only thing holding you back may be your suspension and trans. you didnt mention anything about a bigger stall converter or having the trans rebuilt. you make ten second power but your 60 footers might not be enough to get there.
We are still having our sale on our plate kits. its a great deal and i would definitly look into it. you look like your pretty well setup, only other thing i would recommend is a bottle heater, window switch, and timing tuner
andy670ho Dec 13, 2007 10:20 AM
I run a 150 shot with a nozzle kit, stock suspension, drag radials, heads and cam car with a tranny that hits the rev limiter on the 1-2 shift and I went 10.84 @126 with a 1.49 60 ft.
Cliff Dec 13, 2007 10:41 AM
If you don't have a built trans and with a stock tq converter, I'm guessing your not going to see 10's. More likely your trans is going to go south with a 150 shot. If you don't spray off the line and don't spray through the shifts you could reach your goal, hope so.
Zero4488 Dec 13, 2007 12:00 PM
150 with a good tune you should be a nice 10 second ride...
2002_z28_m6 Dec 13, 2007 12:13 PM
There are stock bottom end ls1's in the mid-low 10's with Cartek h/c. Still street driven here is a link to a post.
https://ls1tech.com/forums/drag-racing-results/828683-10-32-132-35-cartek-stock-bottom-end-heads-cam.html
koolrayz Dec 13, 2007 12:16 PM
You need to make your next mod a 3500 to 400 stall converter. Your MPH is damn near enough to get in the ten's right now. A good stall and the ability to hook are the main things you need. I would think you would only need a very small shot once you get your 60' in line. 11.88 minus .6 to .7 for the stall = knocking on the door to a ten second slip.
Todd157k Dec 13, 2007 01:29 PM
funny, no one mentioned the 3.42 gears. 3.90's or 4.10's would be a big boost.
Bryan @ Speed Inc. Dec 13, 2007 01:40 PM
his mile an hour will probably go down with a torque converter and a better 60'. so i don't think he'll be running tens anytime soon with his current set up.
i'd say a 50 shot might get darn close to a 10.99
eminem1833 - you could install the new NX main line kit that we sell - that will be 50-150 adjustable wet kit which is very affordable, and we have proven it to work very well. We installed the kit on an ls1 car w/ bolt-ons, small (222/222 114) cam ls6 intake, stock heads, and we picked up 112rwhp on a 100 shot with a safe AFR and a couple degrees out of the timing.
just take 1-2 degrees out of the timing and you should be ready to rock.
http://www.ls1speed.com/catagory.cfm?catagory=Nitrous
© 2026 MH Sub I, LLC dba Internet Brands
