Gauge won't stay powered when car on I have the trick perf p series gauge. Works fine with car off. I turn the car on and it keeps resetting. I am gonna try to get a better power and ground for it but other than that, any ideas. |
how do you have the 2 power wires ran...the white wire and the blue/white, and the ground connection are they clean and independant grounds? |
I played with the gauge a bit and am still having issues. My car just got a new battery, Gauge's white wire goes straight to the fusebox. (Tried different circuits with no luck) It is grounded right on the firewall with its own ground. I will try to run it right off the battery |
This is probably related to your other voltage issue with the alternator like I said in your other thread. If I had to guess, the gauge isnt likeing the spikes from the bad voltage regulator in the alternator. |
| All times are GMT -5. The time now is 11:32 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
