Nitrous on 2002 trans am
Old Jun 15, 2008 | 09:09 PM
msheffield's Avatar
Thumbs up Nitrous on 2002 trans am
I have a 2002 trans am, with bolt on mods, and kooks headers. What would be a good nitrous system that is safe for my LS1, and how big of shot?
Old Jun 18, 2008 | 11:15 AM
Chris@NitroDaves
Guest
Posts: n/a
My suggestion would be to go with a plate system. The reason behind that is we are breaking the nitorus and fuel discharges into 6N and 6F which will net you better atomization and more even distribution over a single nozzles 1N and 1F discharge. There is nothing wrong with a single nozzle system it will suite your needs perfectly but IMO i'd go with the plate. Were you wanting a complete package or just a basic system?
Complete Package
http://www.nitrousoutlet.com/catalog...roduct_id=2794
Basic System
http://www.nitrousoutlet.com/catalog...roduct_id=1131
http://www.nitrousoutlet.com/catalog...roduct_id=2885
http://www.nitrousoutlet.com/catalog...roduct_id=2553
Optional for basic system
http://www.nitrousoutlet.com/catalog...roduct_id=2775
Nitrous is run off of bottle pressure so the bottle heater could be the difference between 5 runs with the heater vs getting only 3 runs without the heater
-Chris
Old Jun 18, 2008 | 12:21 PM
Johnnystock's Avatar
single nozzle kicks *** too: I put down 130rwhp more in 98°F with very thick air on very safe and rich tune and 170rwtq
with better air, I'm sure I would have been right around the 150rwhp(150shot).
Plates are really nice of course, but I'm planning to upgrade to a 90mm intake/TB setup so I dont wanna waste money on plate that will not work with this.. and I was on a budget.
Old Jun 18, 2008 | 12:25 PM
you should put a 100-150pill, FPSS, TR6s, bottle heater, a nitrous tune on any wideband and check your a/f and youre set!
And listen to guys at nitrous outlet, excellent service and prices.
Old Jun 18, 2008 | 12:31 PM
camaroride32's Avatar
they make 90mm plates that will fit your application
Old Jun 18, 2008 | 01:13 PM
BLNLS1/RX7's Avatar
792RWHP on mine but I am very careful on how I program it to ramp up on a 300 shot depending on track conditions and other factors.Be sure that you get a system that puts you in control of how much to spray at the RPM you select.
Old Jun 18, 2008 | 01:23 PM
krazy4's Avatar
A single nozzle wet kit will be fine.
Don't forget to get a window switch, bottle heater, purge, and plugs.
A complete kit from nitrous outlet is a good idea, comes with everything.
