HSW dry plate kit with interface
Old 08-11-2008, 12:45 PM
ls1redline's Avatar
Default HSW dry plate kit with interface
Pretty much finalized my decision on purchasing this kit. A few unanswered questions after searching hsw related threads. Car is a 95 camaro yet with a ls1 powerplant. Will I need to upgrade injectors or fuel pump capabilities. Also how does the interface work besides the obvious. I guess how are settings obtained and intitially set?? Is it computer based? Newbie to the LS1 world so any help will be appreciated
Old 08-11-2008, 03:13 PM
JoeyGC5's Avatar
Settings for fuel enrichment and timing adjustment are done by the interface, no need to really d any tune work. What injectors and fuel pump are you currently using? Also any motor work done?
Old 08-11-2008, 03:49 PM
jetlag's Avatar
Simple as flipping a toggle switch! When I had a wideband motoring it, I set the Interface to the correct size, and my A/F ratio was pretty much spot on at 11.7-.8
Also, check out this thread before you order... It is mine, barely used, for sale.
https://ls1tech.com/forums/lsx-parts-sale/942546-dynotune-dry-nitrous-kit-plus-accessories.html
Old 08-11-2008, 05:01 PM
bad6as's Avatar
the hsw dry plate is the way to go! ill be doing it soon i hope. i have the money, but with a 100K and stock bottom end with a cam, is kinda holding me back and if it blows i dont know what i would do. but what are the other mods? mine is a 98 with bolt ons and cam and my injectors are at 98% dc
Old 08-11-2008, 08:09 PM
myfast70's Avatar
I've got HSW's wet plate (same kit but with the addition of fuel) and love it! I'm thinking of eventually converting it into a dual stage dry plate but that won't be until all of my other projects are completed.
Old 08-11-2008, 08:18 PM
red fury's Avatar
Dry shot after the MAF with the interface really looks simple and effective.... I too plan on going this route. A wise man once said "Keep it simple stupid!"
Old 08-11-2008, 08:27 PM
KCJeff's Avatar
I am extremely happy with my decision to purchase the HSW LS1 Dry Plate Kit. Superb quality and terrific customer service.
Old 08-11-2008, 08:28 PM
jetlag's Avatar
It is! I drilled several holes in my lid trying to find a good position but it was always lean.
Ordered an Interface, installed and put nozzle behind the MAF, perfect a/f! Done!
Old 08-11-2008, 08:52 PM
myfast70's Avatar
Hey, I know that guy too
Old 08-12-2008, 09:40 AM
Nick@HSW's Avatar
How many of you guys would be interested in a sale/gb on the dry plates with Interface units?
Nick
Old 08-12-2008, 10:13 AM
ls1redline's Avatar
Nick
I am definatley interested. One other quick question. Your website calls for a 78mm tb application. Technically our throttle bodies are 75mm. Is your kit a direct fit??? Will my stock ls1 injectors and fuel pump be sufficient??
Old 08-12-2008, 10:16 AM
ls1redline's Avatar
No internal motor work with the small exception of heads have upgraded springs/retainers, hardned pushrods and am currently running a tsp 231-237 cam.
Old 08-12-2008, 10:46 AM
Nick@HSW's Avatar
ls1redline, PM sent!
Nick
Old 08-12-2008, 10:52 AM
JoeyGC5's Avatar
No internal motor work with the small exception of heads have upgraded springs and retainers, hadedned pushrods and am currently running a tsp 231-237 cam.
Do you have a fuel pump addition/upgrade? Witht heads and cam setup you'll need extra fuel for the nitrous kit to stay safe and reliable. At least a 255 pump and hot wire harness are basic upgrades to what you currently have.
Old 08-12-2008, 11:11 AM
ls1redline's Avatar
Great thanks for the info. Ill research pumps and go from there
Old 08-12-2008, 12:55 PM
red fury's Avatar
Nick
I might be, shoot me a pm with a projected price and parts included
Thanks
Brian
Old 08-12-2008, 01:41 PM
TOslowTA's Avatar
Nick
interested
Old 08-12-2008, 03:28 PM
bad6as's Avatar
Nick
OMG ME, ME, ME
Old 08-12-2008, 04:10 PM
VIPRETR2's Avatar
Extremely interested.
Old 08-12-2008, 05:22 PM
Nick@HSW's Avatar
Started a new thread guys...https://ls1tech.com/forums/nitrous-oxide/969471-hsw-mid-summer-savings.html Thanks.
Nick
