Used Mtx 342 Amp - $70
Used Mtx 342 amp in perfect factory working order. Feel free to call or text with any questions. 760-521-1847.
Key Features:
» 85 watts RMS x 2 at 4 ohms
» 170 watts RMS x 2 at 2 ohms
» 340 watts RMS x 1 bridged output at 4 ohms
» stereo or bridged mono output
» 4-ohm stable in bridged mode
» Tri-way capable (Tri-Way Crossover required)
» requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
» PWM MOSFET switching power supply
» Intelligent Surface Mount Technology for cleaner sound and greater reliability
» variable (40-200 Hz) high-pass/low-pass crossovers (12 dB/octave in high-pass mode, 24 dB/octave in low-pass mode)
» ThunderEQ Bass Enhancement (0-18 dB bass boost at 40 Hz)
» speaker-level inputs with SmartEngage (turns the amp on when it detects signal from the receiver, eliminating the need for a separate turn-on lead from your receiver)
» preamp outputs
» 10-3/4"W x 2-1/8"H x 9-13/16"
Key Features:
» preamp outputs
