HP VP6121 digital projector!$200 perfect for home theater
The projector needs a new bulb. The old one burnout. The specs are as followsortability and ease of use make the HP vp6121 DLP projector ideal for occasional use, and HP quality ensures durability, even with frequent use. Weighing just 6.7 pounds, the HP vp6121 is extremely compact and portable. It features 2,000 ANSI lumens brightness and a 2000:1 contrast ratio for vivid, crisp images. It offers XGA 1024 x 768 native resolution with a 4:3 or 16:9 image aspect ratio and supports HD resolution. Standard input and output connections make it easy to connect a large number of devices, including anything from your PDA, laptop or PC to your favorite video game, DVD, HD programming (***, Comcast, DirecTv or Dish, etc) or VHS movie. Have a theater in the comfort of your own home. This is an AWESOME projector. Great for the family and kids or just for yourself. It looks sweet on my 120"/10 foot screen.
With automatic source detection, you don't have to figure out different modes and settings. The vp6111 detects your signal input and can automatically resize and synchronize your images to full screen. You can manually switch between computer and video presentations for seemless transitions. The +/- 7 degrees keystone correction keeps your images from appearing distorted and gives you the freedom to place your projector virtually anywhere in a room. The vp6121 can be mounted to the ceiling or tabletop for more permanent installations. Additional attributes include HDTV compatibility, a picture-in-picture function, an integrated 3W speaker, a wireless IR remote control, quiet 35dB operation and eleven on-screen languages.
Included Devices: AC Adapter, PC CABLE, Remote Control, Speakers, Manual
Aspect Ratio: 4:3 (Standard) or 16:9
Brightness: 2000 lumens
Color Depth: 16.7 Million Colors (24-bit)
Contrast Ratio: 2000:1
Interface Type: Audio - RCA Jack, Audio Line In (1/8"" Mini), Serial - RS-232, USB - Universal Serial Bus ""B"", Video - 15 pin High-Density D-shell (VGA), Video - 4 pin mini-DIN (S-Video), Video - 3 x RCA Component RGB, Video - RCA Composite
Light Source Power: 250 W
Light Source Type: UHP Lamp
Resolution: 1024 x 768 (XGA)
Video Standards: HDTV, NTSC (Full)
Display Type: .55 DLP chip (Digital Light Processing)
Weight: 6.6 lbs
MSRP: $1,899.00 USD Item Size: 16.8" x 11" x 13"
Condition: Used
$200.00
reply
You can get a bulb from Circuit City,Best Buy or Ebay. I have seen them as cheap as $200. The bulb went out because when my wife turned it off see also turned the fan off that cools the bulb down.
