Snap On PH3050 Air Hammer NIB
...with cheese.
I've got a Brand New Snap On PH3050 Air Hammer for sale.
I've had this hammer in a cabinet since I moved and could use the money. I'm selling it at a loss rather than have to wait on an ebay auction. I'll tell you from experience in dealerships... this is the one to have. Not to mention it's Snap On; it's tough to get any better.
http://buy1.snapon.com/catalog/item....re&dir=catalog
PH3050 Features
• Dual Elastomer Cushions (DEC system)— absorbs shock and vibration to reduce user fatigue.
• Phenolic (Kevlar reinforced) Flutter Disc—strong composite disc for long life.
• Direct Multi-Port Frontal Exhaust—designed to keep air and debris away from user.
• High Grade Steel Barrel—solid high grade steel provides greater strength.
• Variable Speed Soft Elastomeric Trigger—featherability with greater control and comfort.
• Contoured Aluminum Handle—lightweight T-handle design provides exceptional balance.
• Four Position Built-in Air Regulator—vary power and select the proper setting for differing applications.
• Air Line Filter—helps prevent foreign particles from clogging trigger mechanism.
• Power Packed Piston—delivers harder blows with a hardened steel piston for maximum impact.
• Increased Power—heavier piston with a longer stroke produces a harder hitting blow for heavy duty hammering applications.
• Made in USA.
Stock # PH3050
Name Hammer, Air, Super Duty (2,500 BPM)
Price** $289.00
Brand Snap-on
Air Inlet Thread Size 1/4"-18 NPT
Blows per Minute 2,500
Recommended Air Pressure, psig (kPa) 90 (620)
Recommended Hose Size, inches (mm) 5/16 (8) ID Min.
Description Heavy-Duty Air Hammer
Chuck Bit Size, inches/mm .401 (10.2) shank diameter
Air Consumption, average, cfm (scfm) [l/min] 1.8 (12) [60]
Piston Stroke, inches (mm) 3 (76)
Vibration Level 1.5 m/s²
Vinyl Boot PH3050BOOT (optional)
Sound Pressure Level, dBa 94
Weight, lbs. (kg) 4.95 (2.3)
Overall Length, inches (mm) 8.95 (229)
You'll pay $289 on the website or off the truck. Not to mention tax/shipping.
I need $200 +actual shipping.
I might be interested in trades also.
Like I said, my loss your gain.
PH3050 Features
• Made in USA.
Stock # PH3050
Price** $289.00
Brand Snap-on
...with cheese.
I've also got this listed on GarageJournal.com. If non of you guys are interested I'll just stick it on ebay this time tommorrow morning. Thanks for the interest!
