Fuel injector leaking
The injector is leaking were it is connected to the fuel rail... Its like there is a small pin hole or maybe a rubber gromet that has a fine crack in it.
Were can I get a replacment Seal/Gromet at for the Fuel injector?
And I have never had to take these type injectors off before, is there a special tool needed? Or are they just pressur fitted in there?
Help me out. thanks
Help me out. thanks
They just pull right off. I'm sure someone here on the sight has one. I know Ellis has a few at his place. Make sure you use a little bit of Dialectic grease when you put it back on. You might be able to get one at the dealer
Slides on, slides off. Just a rubber o-ring to seal it up. Like doug said, use some grease otherwise it's a bitch to get back in the rail and you stand a chance of ruining the seal.
