Northwest Members WA, OR, ID, MT, WY, SD, ND
POST UP! Plans and goals for next race season
Old 03-26-2017, 09:09 PM
  #41
y2keglide's Avatar
Not really building a track car but will probably do PIR some night to see what she'll run.
Basically building a road burner for back road fun and a few road trips.
Bought her in mid Sept. and garaged early Oct. so very little seat time so far.
Have her scheduled at Wong's performance in Vancouver,Wa May 1st for the following mods, have most of the parts rat-holed already.
LS6 heads with Comp Cams double valve springs.
Comp Cams .617/.592 lift camshaft.
GM Performance LS7 lifters.
Comp Cams hardened pushrods.
GM Performance oil pump.
Katech C5-R timing chain on GM Performance sprockets.
American Racing stainless long tube headers and y-pipe (no cats).
GM Performance LS7 clutch kit.
RAM 19.5 lb. aluminum flywheel.
ARP pressure plate and flywheel bolts.
Tick Performance adjustable clutch master cylinder.
GM Performance clutch slave cylinder.
Tick Performance clutch slave speed bleeder.
MGW short throw shifter.
Prothane motor and trans mounts.
Midwest chassis driveline loop.
BMR bolt in subframe connectors.
BMR tubular torque arm and relocation crossmember.
BMR tubular adjustable panhard rod.
UMI tubular roto-joint adjustable lower control arms.
BMR front shock tower brace.
Strano master brake cylinder brace.
UMI tubular roadrace front K-member.
UMI tubular lower A-arms.
Global West tubular upper A-arms.
Strano hollow 35mm front and 22mm rear sway bars.
Strano lowering springs.
Old 03-29-2017, 10:08 PM
  #42
7 Second Club
GotBoostRacing's Avatar
Originally Posted by nogomofo1970
I missed a good test day. I was getting some good points with the family since I've been working on car stuff pretty heavy for the last few weeks
There was nobody out there, you could have gotten 10+ passes in easy.
Old 04-03-2017, 07:47 AM
  #43
nogomofo1970's Avatar
Well it looks like this weekend is a wash. I Guess ill go to the Swap Meet!
Quick Reply: POST UP! Plans and goals for next race season
