Northwest Members WA, OR, ID, MT, WY, SD, ND
does anyone run 4:10's on 17inch wheels?
Old 10-22-2005, 09:58 PM
00Vette's Avatar
Default does anyone run 4:10's on 17inch wheels?
I was just reading another thread and got to thinking..........I have 3:90 gears and will be running them on 17inch rims with 315/35 DR's. That might be a problem. I do have my rev limiter set to 6800rpms.........
Has anyone ran a setup similar or Identical to mine?
I don't want to run out of gear at the end of the track.
Old 10-23-2005, 01:09 PM
00Vette's Avatar
I guess everyone is using slicks or other size DR setups.
Old 10-23-2005, 01:17 PM
Poik's Avatar
315/35 should be like 26" which is probably right around your stock tire height, and if you redline at 6800, I really doubt you'll be running out of gear in 4th trapping 113. But I dont know, just taking a wild guess..
Old 10-23-2005, 01:24 PM
00Vette's Avatar
There was another guy who was running 4:11's with 275/35/17's and had to shift into 5th. I found out he was hitting his limiter at like 6200 or something. Either way.........it raised my eyebrows.
Old 10-23-2005, 02:08 PM
WAHUSKER's Avatar
I run 315 DRs & 4.10s & go thru the traps @ 6k, but I have an A4. If your M6 gear ratios are the same as an f-body, then you should be able to hit 128 mph in 4th @ 6800 rpm. Which would be good for low 11s......
Old 10-23-2005, 03:23 PM
00Vette's Avatar
Very good information............that's all I needed to know.
So are you going to stick with DR's with your new setup? Or are you going with slicks?
Old 10-23-2005, 05:21 PM
WAHUSKER's Avatar
I probably will run the DRs the first time out just to see how they stick...or should I say IF. Once the car gets moving they should hold it. Just not sure how hard it will end up launching. Right now the tires do not spin. I eventually plan to run 11.5" x 27-28" x 15" slicks. But it would be fun to drive the car to the track & run 10s in street trim...
Old 10-23-2005, 05:38 PM
Chris Stewart's Avatar
Use this calculator and you can try some different combos:
Gear ratio calculator
Old 10-24-2005, 08:39 AM
00Vette's Avatar
That would be neat..........I can't wait till next season. It's going to be a good year.
Old 10-24-2005, 08:53 AM
sardog46's Avatar
Tens.........yhea right in the 1/8
Also rememebr mark you just added about 2-300lbs to the car. That tire should hook preety damn good, I know my qtp's in that size hooked real nice.
I had 4:10 with a 275/40/zr17 for a while and on motor i would cross low in the rpm range about 6400, mybee a little higher. If that helps.
Old 10-24-2005, 08:20 PM
00Vette's Avatar
Okay............So with my 3:90's I should cross at around 6000rpms. That works for me. It gives me leway to be diverse in my setup......not to mention I'll be adding nitrous too.
Old 10-24-2005, 11:31 PM
sardog46's Avatar
With the spray you better go to a taller tire. when I was on the juice I had to run a 28 inch slick just to keep it under 7300 over the line. just remember on the juice it is a whole new ballgame
Old 10-25-2005, 08:20 AM
00Vette's Avatar
Good to know.............I wasn't aware of that! My car has been lowered, and I don't think a tire that tall will work.
Old 10-25-2005, 08:48 AM
sardog46's Avatar
Had to do some trimming to make it fit on mine, which reminds me.
MArk to get the 28 to fit right i hope you have adjustable lca and a good sawzall for trimming the wheel wells.
Old 10-25-2005, 08:52 AM
00Vette's Avatar
I guess I'll worry about it when its time to cross that bridge......
Old 10-25-2005, 10:32 AM
WAHUSKER's Avatar
Right.....I am NOT cutting my wheel wells, OR grinding my calipers, so I was planning to run 27 x 11.5 x 15 Hoosier QTPs on Bogarts.
Old 10-25-2005, 01:09 PM
sardog46's Avatar
With the 11.5 you might have to beat in the inner fender well. also make shure you check to see if the bumpstops rub, which they might.
Old 10-25-2005, 08:04 PM
00Vette's Avatar
I'd like to run some ET streets. What kind of rim should I get ($ is an issue here) and what tire size should I run? Remember my car is lowered quite a bit.
Old 10-29-2005, 12:23 PM
Moderator
John B's Avatar
I run 315/35's with 4.10s, trap at 115+ and it's not an issue.
Old 10-29-2005, 05:06 PM
00Vette's Avatar
Yeah...........but do you have a T56 tranny?
