Northwest Members WA, OR, ID, MT, WY, SD, ND
3" disk (where can I get one?)
Old 11-01-2005, 03:34 PM
KrautBurner's Avatar
Default 3" disk (where can I get one?)
I need a 3" disk (like a washer but with no hole in the middle)
needs to be relatively strong, 1/8" plastic
I do have a square of 1/8 (0.125 inch) aluminum,
but no way to cut it
any idea's would be awesome,
Russ
Old 11-01-2005, 04:50 PM
Ackattack1's Avatar
can you use a jig saw to cut the Al? or a pair of tin snips, or does it have to be more exact?
Old 11-01-2005, 04:57 PM
Poik's Avatar
At my house I have a tool that you put in a drill press that you can change the diameter of. It's basically a sharp edge that spins in a circle and you just slowly cut away.. Might want to try to find one of those.
Old 11-03-2005, 01:31 AM
that would have worked perfect,
but Mike (with the broken driveshaft) helped me out,
we used his dremel and bench grinder
I ended up getting some staneless.
worked great.
i just got outta the hot tub, working fine.
Russ
