Anybody need a big turbo?
http://bellingham.craigslist.org/pts/258055894.html
Someone buy that and try to make it spool, I dare you.
Tech Addict
It's safety wired together. What a monster. Looks like a pretty good sized oil tube feeding the bearings.
When I ran and tested the emergency generator at the north creek plant both turbos would glow entirely cherry red after it was fully loaded up, as would the whole intake tract for the motor. 1100hp V8 Cat Diesel. The bearings for the turbos had 5/8" oil feed lines. It was ****** awesome!
Tech Addict
Originally Posted by NWDragRacer
I worked on some natural gas compressor systems that had turbos that were about 6 feet in diameter. They were in a seperate building outside of the engine room. The V12 engines were 4,000 horsepower at 300 rpm! Now that's some serious torque. The turbos had air motors to get them spinning prior to engine start because the impellers and shaft weighed about 300 lbs. The piston rings were almost 5' in diameter.
Did you see Modern Marvels "Horsepower" episode on The History Channel, they showed a container ship diesel that made 100,000 HP, you could walk into the crankcase. They must have had a 6ft throw on the cranks. Some rediculously low rpm.
Krikey! I'd friggin love to see that.
But it still won't fit under the hood.....
